Results 1 to 10 of 21
Thread: Going Solar need your help
    Ocoee, Florida
    Default Going Solar need your help
    We are having a Solar Heater rep coming today. Are there things I should be looking at and questions to ask? Are there different types of panels to consider? What's the best? Thanks
    15,000 gallon IG free form 16x32 w/attached IG 6x7 spa. Aquapure SWG, Jandy Aqualink 4 w/ PDA, Paramount infloor cleaning system, Starite 400K propane heater, Starite system 3 filter, Starite 2hp pump, polaris D'Light LED pool and spa light and paver decking. Completed in 11 weeks 7/4/06.
    Poughquag, New York, USA.
    Default Re: Going Solar need your help
    Go to www.powermat.com as a starting point. The website is busy but extremely detailed (***uming that you are going for a permanent installation) and you will learn a lot. I can also recommend looking at the Solar Living Inc. website (www.capturethesun.com) and the www.flasolar.com website. All have good info.
    I would come back here with the rep's recommendations and those of us with solar can review.
    Mainly, you are interested in the things you would with any normal contractor (reliability, insurance, references). I would also ask for references that you can go see the job, solar can look really ugly, or not so bad depending on the install. You will want an automatic controller for any sizable installation. While I wouldn't go overboard, I would recommend getting as much coverage as possible for your budget and area, its more expensive and h***le to add panels or banks.
    I would throw out a few terms that you learn about on powermat.com, like "drain back" and vacuum breaker. I would ask them if they plan to tilt the panels so that the air purges correctly and the water can run out for winterizing (all after they explain things to you first). I would do all of this just to see how knowledgeable they are. Again, come back with recommendations and impressions. Good luck, solar is wonderful.
    Ocoee, Florida
    Ok, I have narrowed the field down to two companies. Placement of the panels would have to be on the West side of roof and north side, this is the best solution with respect to the sun. In the winter the sun is at the front of our home and the summer at the back. They both said max sf of paneles on the west side would be 300sf and 76sf on the north (not sure what this means though) with an average temp increase of 10-12 degrees, ideally they would have wanted 400-450sf. Ideally we'd like to extend our season into mid Nov. here in FL with a pool temp of 80 degrees. Of course we would purchase a solar cover (any suggestions on what is the best one) and keep it over the pool when not in use. Does anyone else have any other input or suggestions? Maybe a Heat Pump? Pros and Cons....
    Solar design layout:
    Pool has 430 sf surface area
    Westside of roof~ (4) 1/2 4X10 1/2 panels and (3) 4X9 1/2 panels
    Northside ~ (1 3/4) 4X10 1/2 panels
    Total solar surface area of 376 sf.
    I would ditch the north facing panels. According to everything I've read, panels that are much north of direct east/west are a waste of money. Maybe it is different in FL, though.
    Seems to me that the if you really are getting 300 sq/ft of panels on a 430 sq/ft pool, you should easily get your pool up into the high 80s for most of the year in FL. (I can't figure out how you are winding up with 300 sq ft based on 4 4x10 panels, maybe I am incorrectly reading what you wrote). I think the year round part is what drives solar installers in FL to add more panels than we would here in NY. That would give you close to 70% coverage, which is generally considered more than adequate.
    A good heat pump is certainly an alternative. Generally, it is a bit more expensive to install (if you get a really good one) and it costs more to run, but it may be your best option. There are solar panels that are built directly into the pool deck, one of the forum members has them, perhaps that would work as well.
    Ocoee, Florida
    Quote Originally Posted by tphaggerty View Post
    Forgot to put in that there are (3) 4X9 1/2 panels also going on the West side.
    So putting the extra panels on the north side would be a waste? They will do this for me for an extra 200 bucks. Would having this extra panels give me any extra benefit in heating. They are telling me I should expect a 10-12 temp increase.
    From what I've read, no, the north facing panels really won't contribute to the heat generation. I tend to be an advocate of "get more early" for solar panels. Mainly because I've learned the hard way. I am in the process of adding a 2nd bank, not so much for absolute temp increase, but for quicker heat recovery after bad weather. But, north is just not good with solar panels, the sun is not on them long enough.
    However, the angle of the roof definitely makes a difference. If you have a flatter roof, maybe it will work. I don't think it will hurt. Push come to shove, I think I would do it for 200 bucks.
    One thing you might consider is going to powermat.com and looking at their powerstrip line. These can be custom cut and constructed so they can often provide more coverage (they be setup to follow roof angles, etc.). You might be able to use more of your roof with these.
    Ocoee, Florida
    Default Re: Going Solar or Heat Pump Help
    Need a little extra now. I've had another solar rep come to give their opinion and what I'm getting is max panels is 7 where 12 is needed. He put his honest opinion forward and said the best resuls to heat the pool would be a heat pump. Suggesting a Aquatherm 114K BTU. Now he mostly does solar with heat pumps secondary, so I'm thinking he's giving an honest opinion. Any thoughts on a heat pump vs solar. I know a heat pump will have an operating cost but I'll get more then a 8-9 degree increase with solar. Thanks
    Panels can face East or West, but North is a waste generally. But watch where the sun is. It moves South in the winter, and North in the summer. For me the difference is SIGNIFICANT and I turn panels on and off accordingly.
    Solar heat isn't just "heat". You have to decide what you what it for, when you want it, and how much you want. Typically, salesmen tell you the panels should have a surface area near that of the pool. Like all things, this depends on what you expect of them. My panels are only about 35% of my pool's surface but they do GREAT because of what I expect them to do: Extend my swimming season to early May and mid-to-late September, and warm the pool during the summer so it isn't a shock to get in--and that's living in Northern NJ.
    Most solar systems have the advantage of being easily expandable--especially the rollable panels--so you can always make a small system bigger if it is not adequate.
    Solar's BIGGEST advantages are that it is basically free to operate--just the pump, but the heat is free, and it can double as a cooling system merely by running it at night. It's disadvantage is that it doesn't work without sun, or in the rain.
    After having tried the opaque blue-on-top, black-on-bottom cover, the transparent blue cover, and the totally clear heavy-weight cover, I like the last best. Heavier covers insulate more and take longer to pop their bubbles. Clear covers allow the sunlight to penetrate the water and heat it directly, rather than trying to use conduction and convection currents.
    Last, if you get a reel, get a good one, a metal one. I don't like the plastic ones--I had the plastic bearings self-destruct, making it hard to turn, and then the handles broke!
    Ocoee, Florida
    Thanks Carl
    I would be getting approx. 75% of my surface area. I'd love to be able to extend season to mid Nov (Florida). If I go heat pump I could heat pool year round, but at a cost. The panels would amount to 7 on my West side. Any thoughs on heat pump?
    Jul 2006
    Nova Scotia CANADA
    Heat Pumps are awesome!
    Everyone I know (locally) has closed up over a month ago; we're still swimming ( even though we've already been having "frost" at night & the leaves have half changed already)
    Being that you're in florida, you could literally swim all-year-round
    If you have the cash, I'd go with solar panels & a heat pump.
    just set the heat pump to the "minimum" temperature that you like to swim at...
    & let the solar panels bring it up to what you really like the temperature to be at ...
    Happy Swimming :-)
    ( I'm so envious... wish I could swim year-round...lol)
  1. Passive Heat Using Homemade Solar Disks
    By alisonquilts in forum Pool Equipment & Operations
    Last Post: 06-09-2012, 08:59 AM
  2. Heliocol vs. Solar Industries for solar heating
    By KevinSDiego in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 04:22 PM
  3. Replacing Solar thermal and natural gas with Solar PV and electric pool heater
    By California Newbie in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 08:14 PM
  4. Solar Panels and Solar Covers
    By FlowerPool in forum Intex-type Pool Setup & Operations
    Last Post: 05-22-2012, 07:12 PM
  5. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
