Re: Going Solar need your help
Go to www.powermat.com as a starting point. The website is busy but extremely detailed (***uming that you are going for a permanent installation) and you will learn a lot. I can also recommend looking at the Solar Living Inc. website (www.capturethesun.com) and the www.flasolar.com website. All have good info.
I would come back here with the rep's recommendations and those of us with solar can review.
Mainly, you are interested in the things you would with any normal contractor (reliability, insurance, references). I would also ask for references that you can go see the job, solar can look really ugly, or not so bad depending on the install. You will want an automatic controller for any sizable installation. While I wouldn't go overboard, I would recommend getting as much coverage as possible for your budget and area, its more expensive and h***le to add panels or banks.
I would throw out a few terms that you learn about on powermat.com, like "drain back" and vacuum breaker. I would ask them if they plan to tilt the panels so that the air purges correctly and the water can run out for winterizing (all after they explain things to you first). I would do all of this just to see how knowledgeable they are. Again, come back with recommendations and impressions. Good luck, solar is wonderful.
