Re: Do I take CYA into consideration?
Many thanks for your advice.
I have a plaster/gunite pool, and yes, I use Triclor tablets. The tablets are 3" and are used via a Pentair automatic cholorine inline feeder. This year I have kept the input valve of the feeder at a pretty low level (around 2) so I have only used 1 large tub of these tablets in the last 12 months. If I have needed to boost the chlorine I have used ordinary bleach poured around directly into the pool.
I have only started to worry about the TA because its only just gone up to 160 - but from your reply I'm beginning to think that maybe I don't need to worry about it too much at this stage??
