Super Gizzmo
To be sure I get the correct thing (Gizzmo) for the skimmer can you post a link to someplace on line that sells the one mentioned ? With the "Super Gizzmo" I assume I put teflon tape on the threads, screw it in, undo the cap, Blow the line, then place the cap back on. Since I will be leaving the water level up should I also put a closed cell foam noodle in the skimmer ?
PS:
As far as my pool guy being a idiot you are totally correct !!
