Results 1 to 10 of 11
Thread: Newly converted...how do I lower combined chlorine level?
    Jul 2006
    Rochester, NY
    Question Newly converted...how do I lower combined chlorine level?
    Hi there -
    I received Ben's test kit last week and went right to work converting my Baqua-crud pool to the First Church of BBB. It took about 4 full days.
    Everything seemed to go just as described by most other converts in this forum (pictures to follow), and I thank each and every one of you. Your posts have been invaluable to me.
    Now I'm ready to level-off the rest of my chemicals and button-up the pool for the winter.
    Here are my present vitals:
    Pool: Above ground vinyl, est. 12,500 gallons
    Location: Upstate NY (we typically endure long, below freezing winters with occasional fluke temperature fluctuations)
    FC: 5
    CC: 2
    TC: 7
    pH: 7.2
    Alk: 140
    Cal: 140
    Cya: 0
    For starters, I just added 4.5 pounds of Cya, so we'll see what that does.
    Can someone steer me from here? And how can I get my CC to 0? It seems it's going down ever so slowly, but is there something I can or should do to speed things up a bit?
    Thanks in advance.
    Default Re: Newly converted...how do I lower combined chlorine level?
    To get your CC to zero, take your chlorine up to about 10 ppm and hold it there until the CC is gone. Otherwise, your numbers look pretty good! Congrats on the conversion, you won't be sorry.
    Tennessee
    To add to Janet
    Dirtect sun can also help to lower CC so if you have the pool cover on you might pull it for a day or two.
    duraleigh Guest
    Adding a little more, I think Janet missed your addition of 4.5 lbs stabilizer....bringing you to about 40-50ppm.
    About 3 more gallons of 6% clorox added initially and then holding your FC @ 15ppm will "shock" your pool and get rid of the CC.
    Read the stickies at the top of the water forums for more info on shocking.
    Ontario.
    Another year, I wouldn't bring my CYA up this late in the season. By spring there won't be much left.
    Jul 2006
    Rochester, NY
    Thanks for all of your good advice. I'll follow it and letcha know.
    Jul 2006
    Rochester, NY
    Here are my numbers this morning:
    Location: Upstate NY (we typically endure long, below freezing winters with occasional fluke temperature fluctuations)FC: 11.5
    FC: 11.5
    CC: 1.5
    TC: 13
    pH: 7.1
    Alk: 140
    Cal: 140
    Cya: 45
    It's looking like the perfect day to close my pool today, but I'm concerned with my CC level. Do I need to bring the level to zero before I close it? Also, not sure why the pH went down. You'd think with the additional chlorine that it would have gone up.
    Would it harm anything to close the pool as is and rebalance the chemicals in the spring when I open it? Also, what is your opinion on adding Polyquat 60% algecide before I close? I've read that some people use it, while others don't.
    Thanks again for your help.
    duraleigh Guest
    Double check your CYA results and repost them
    Jul 2006
    Rochester, NY
    Whoops, I meant that my Cya is 45, not 145 - sorry - I edited my last post to reflect the correct reading.
    duraleigh Guest
    Yeah, I was pretty sure that was a typo. I would suggest one more dose of chlorine to reach breakpoint (shock) and get virtuallu all the CC's out of there. It will probably have dropped some more so test again, and add enough to bring it up to 15-18ppm total.....that should clear up almost all the bugs.
    I personally don't use polyquat but I don't close my pool, either. Most folks that close do seem to use it as part of the closing process. Others more informed than me can help.
    By the way, those are nice pool numbers.....good work!
  1. Need help getting rid of 7 ppm combined chlorine
    By mtroyalm2 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-10-2012, 10:04 PM
  2. New Saltwater Pool---How to lower the water level with autofill?
    By AmHistoryNut in forum Pool Equipment & Operations
    Last Post: 03-11-2012, 03:17 PM
  3. how to lower water level using pool pump
    By johninmartinez in forum Pool Equipment & Operations
    Last Post: 01-28-2012, 06:35 PM
  4. High combined chlorine level won't budge
    By Carolina in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-13-2006, 09:54 PM
  5. Pictures of my pool during the week I converted to chlorine (bleach).
    By Gracie in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-29-2006, 07:53 PM
