Hi all,
I have a 26,000 gal IG diamond brite plaster pool that is 3 years old. Using a Aquarite SWG. The salt is at 2600ppm per the digital readout on the control unit, and the indoor controller. Was getting a low salt indicator, and flashing check cell indicator lites. Added 40 lbs of salt 1 week ago, reading went up to 2700 for a few days now back at 2600ppm and again low salt indicator, and intermittent flashing check cell lite. Had the salt checked by 2 pool stores, one said it was at 3600ppm, the other said 4,000ppm.
Readings today:
Cl-2
FC-2
PH-7.6
ALK-100
CAL Hard-250
Phosphates- 100 (I assume PPB?)
CYA-40? (My test indicated 20 ppm. One store said CYA was 0 ppm, the other said 40 ppm.)
I checked the turbo cell for scale build-up but there was none. I did soak the cell in diluted acid just to be sure. No change in the salt reading.
My question is how do you determine if the cell is failing? Is it possible the circuit boards in the control unit are causing problems?
Any help in properly diagnosing this would be greatly appreciated.
Gary
