Results 1 to 3 of 3
Thread: Sand in my pool?
    Jul 2006
    Default Sand in my pool?
    A couple of weeks ago, I put some filter cleaner in my sand filter. The cleaner directions said the run the pump with the cleaner in it, and I think I might have turned the pump back on with the multiport valve thing set in the wrong direction because now, there is sand one the bottom of my pool. I put the hayward pool vac in and it gets sucked up, but the next day it is there again, and again, and again.... I thought that maybe I have sand in my pipes, and it just gets pumped into the pool a little at a time.... Is that what is happening? What is the problem and how do I fix it?
    Thanks,
    Ed
    Honesdale PA
    Default Re: Sand in my pool?
    Ed,
    Welcome to the forum. If there is sand in the pipes it will get blown out fast so this is not why the stuff keeps coming back. The only way I can think of something that you put in getting blown back to the pool is if you did it with the valve set to Backwash then did not do a Rinse before switching to Filter. Are you sure the stuff in the pool is sand? Can be confusing sometimes. If the stuff gets kicked up very easily it could be silt, pollen, or any fine stuff the filter won't catch. Filter sand will definitely be gritty. Check these things and post back. we'll eventually figure what's going on.
    Edit: Some on this forum recommend all sorts of maintenance things for sand filters. Using cleaners, tearing apart, washing, etc. I'm on my 9th season with a 300# Hayward sand filter and do nothing but backwash when needed and add a little DE powder after a backwash to assist in filtering smaller stuff. Sand filters are the easiest and cheapest to maintain.
    I had the same thing. Found out after you backwash, you then go to rinse for a less then a minute and then click to filter, turn on pumps and I see no more sand coming out of the jets. Unlike before also.
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
