Re: Not having success with BBB in my hot tub
Cool, yea we just got it this year, its the camel brown color (colour for us Canadians) with the blue water pattern and swirly tile top, it is actually the same liner as our pool, how coordinated! We only have the bi-fold top... should we look into getting all the winter stuff??? I guess I can find out this winter. It seems to stay pretty warm under the cover. I hear you about the heat level, after sitting in it for 5 minutes you get used to the heat and want it higher. Too bad there wasnt a 106 level! I guess since the method that it uses to heat the tub (via motor heat) it cant go above 104.
Sorry to hi-jack the thread a smidgen.
