Results 1 to 10 of 18
Thread: Newbie here...need help with startup
    Scottsdale, Arizona
    Default Re: Newbie here...need help with startup
    If it's a plaster pool, you need to be brushing it a couple times a day ... Get the filter running asap.
    Put the PB number on speed dial in your cell and do not stop calling until they get the job done!!! It's sad but your problems are typical in the industry. My PB started to drag his feet late in the project and once the promised completion date arrived, I called and informed them I would be deducting 100.00 per day from the balance due for each day it was not completed. That got their attention.
    The pool finish is plaster...
    I finally took the bull by the horns Friday night after deciding that I wasnt going to get any help from the PB...after all, why would they want to start providing good service now after a perfect record of being absolutley incapable for the last two and a half months?
    I removed the plugs from the skimmers and filled the pumps with water. I walked around the pool one more time to make sure all of the plugs were removed and the main drain was clear of debris...I walked back to the Easy Touch controll panel and turned on the pool pump, said a couple of hail mary's and low and behold...we have lift off. Everything came on line perfectly. I had a few monments of trial and error trying to make sure that the valves all did what I thought they did. once I got everything figured out we were off to the races and at least i wasnt looking at stagnant water anymore.
    I went down to the local pool store and took my beating like a man, since my PB has not delivered a pole or brush or anything else for that matter I decided to buy one for now and show them the reciept when they arrive to pick up their final check. I havent had a chance to test the water yet but I will do that tonight and post the results tomorrow. It was nice to have things up and running even if it wasnt "the real thing". I hope to get the start up company out this week to add the salt and help me program the Easy Touch.
    One thing I noticed that I dont understand is the jets in the spa are missing...does anyone know when they are normally installed?
    I took a few pictures on Saturday evening, sorry they are so dark. I will take more when I get a chance. Thanks again for all of the help, I will get the results of my tests posted tomorrow.
    SeanB. is offline --General User-- Weir Watcher SeanB. 0
    Missouri City, Texas
    Well, it looks good anyway. I like the layout and the shape of the spa.
    Just curious, did you get the landscaping package from them as well or will you be doing that yourself?
    Site owner -- www.troublefreepool.com
    Sugar Land, Texas
    Quote Originally Posted by Ready2swim View Post
    Do you mean that there is nothing coming through the gunite wall where the jets should be?
    Or that the appropriate wall fittings are not yet in place?
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
    Sanford, FL
    If the jets you are refering to are really the eyelets - mine were installed the week after the pool was filled. Our start-up went like this
    8/18: finish applied and started filling
    8/19: completed filling - electrical came out to connect the pump - ran out of materials & left.
    8/20: Nothing
    8/21: Electrical came back and got the pump on-line and started. PB came to install lights in spa and pool. Found a broken conduit.
    8/22: PB came back - fixed conduit - got the lights installed. Found SWCG was plumbed wrong. Installed eyelets.
    8/23-24: Nothing
    8/25: Got pool school - they added the rest of the chemicals and we got our brush/test kit/warranty info and we paid final payment. Items still not completed at this point were (1) the SWCG was still not started (2) some pavers were the wrong color (3) the covered area leaks by the house (4) the screen door on one side hits the pavers and is very difficult to close (5) paint overspray on tiles.
    8/28 - fixed overspray on tiles
    8/31 - started SWCG - added salt
    9/08 - installed alarms on windows/doors
    9/19 - final inspection. Still outstanding items.
    This is normal punch-list type stuff. They are talking to me - I never call angery - no one wants to call someone back that is going to yell at them - so I only am a b**ch when I have tried everything else.
    Take a deep breath - your scenario doesn't sound nearly as bad as some others I have heard (14 + months from dig to fill). Although it is never good business practices to lie to a customer - will get you in trouble everytime.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Simonn's that is kind of what I was thinking. I know pools are a pretty expensive proposition, and to tell the truth, very few people seem to be getting the kind of customer service you'd expect with that sort of expenditure.
    However, it all seems very similar to the home building process, which we just finished. Despite spending many times the cost of the pool, we ran into the same sort of issues - things getting done slowly, sometimes wrong, but eventually all was made right.
    In both cases, the builders are relying very heavily on contracted labor who in most cases (in this part of the country) are illegal and most barely speak English. I can see why communication and timeliness are big issues. However, the work ethic of these people seems to be fantastic. Once they start on a job, they are usually very skilled and do well.
    Just as an example of how delays happen, we wanted to save some money on putting our fence back up, so I approached a laborer building a house next to us (lots of construction still going on) and asked him if he could repair my fence - about 15 foot or so. This would have cost me several hundred thought the builder and he agreed to do it for $75. The funny part is he didn't wait until the end of the day to come over, he came and started right then and did the job - took him about an hour. Now, I was glad to get my fence done, but I couldn't help but think that he was probably being paid to do another job at that same time. A job that was now delayed because of me and my fence. Now the builder certainly couldn't account for that sort of thing, but the guy buying that home is going to hold the builder accountable for those delays.
    I guess, after my own experiences and reading about enough other builds, I was prepared for delays, so I'm able to just take them in stride as part of the process. Not to negate anyone's aggravation, because there is absolutely room for improvement across this whole industry.
    OK guys,
    Here is my dilemma,
    The test Kit that my PB provided with my "package" only measures CL and PH and it only does it with a color chart that is weak at best. I will have to run down and pick something up for now that will give me some true data.
    Everything else seems to be going well, we are expecting final clean up tomorrow and that should be that.
    How's about an updated picture? How are things running now?
