I guess I need to shock to at least 15PPM or higher to kill this algae.
10000 gal CYA is 40PPM. My question is how can I vacuum w/ a CL level this high? I'm sure I don't want to get in the pool water, can I run my Baracuda auto-cleaner?
You can get in the water, it won't hurt you, although you may want to wear an old suit. You can run your cleaner too.![]()
Northeast PA
