I have read Watermom's sticky about closing an AG pool and I feel like an idiot asking this but will anyway....
If the first step in closing is to clean the pool very thoroughly and THEN add the chems and balance the water, all over a period of a couple of days so the chlorine gets a chance to vent before I put the solid cover on it....
How do I keep it clean while all of the above is going on so I don't have to clean it all over again and unbalance the water? We have leaves and blowing dirt that will wind up on the bottom. I am using a solar cover now to keep the heater's heat in the water which helps some but stuff still winds up on the bottom.
And if I'm using a solid cover - not the nasty black mesh tarp thing - do I need to use Polyquat?
Thanks.
CoffeeBean
. If your pool has no large debris and you have added some algicide and a 'shock level' of bleach, you shouldn't have a problem, come next spring.
