Okay - I have Ben's kit - but I am getting very different test results for the CYA reading than the dreaded pool store.
2 weeks ago:
My test = <20
Pool store = 40
*Added 2 lbs of stabilizer (target is 60-80)*
This last weekend (7 days after adding CYA)
My test = <20
Pool store = 40
I haven't added anymore. This is the only CYA I have added. Other sources would be from the pool builder - who supposedly added enough to get to the 60-80 range and about nine (9) one-inch tri-chlor pucks I was using before the SWCG start-up.
Should I add more?
My chlorine level has jumped from 3ppm at the first SWCG start-up to about 5ppm - so I have turned down the SWCG. However the lower chlorine usage could also be due to lower temps???
