How much algaecide should I add to 18,000 galon IG vinyl for winter? I live in Harford County, Maryland.
Thanks, Marty
Thanks, Marty
The dosage will be on the label.
Thanks Dave,
I didn,t know if more would be better or if it would have any negative effects on the rest of the water chemistry.
Marty
Gotcha' now. I personally don't use it but those that do seem to indicate it's fine to overdose a little. Others better informed will give you a more accurate opinion.
Just make sure you are using polyquat algaecide.
CaryB
I usually add a double dose when closing per Ben's instructions.
