Closed Thread
Results 1 to 9 of 9
Thread: Algaecide
    .Joppa, Maryland
    Default Re: Algaecide
    Thanks Dave,
    I didn,t know if more would be better or if it would have any negative effects on the rest of the water chemistry.
    Marty
    duraleigh Guest
    Gotcha' now. I personally don't use it but those that do seem to indicate it's fine to overdose a little. Others better informed will give you a more accurate opinion.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Just make sure you are using polyquat algaecide.
    CaryB
    Dec 2005
    Lakewood, CO, USA.
    Where are Ben's instructions?
    I think the standard for the Polyquat 60s was 9oz (initial treatments) -16oz (visible algae) per 10k of water - I put in 32oz today to prep for closing (the size of one bottle)
Closed Thread
