pool deck
hi have a 15x30 ew pool and planning to build a deck.I was trying to descide
what to use for the decking.i have a composite deck that the pool deck will
attach to. the composite deck get so hot you can walk on it with bare feet.
i was thinking of using marine plywood and covering it with indoor outdoor
carpet like the stuff used on aluminum decks.does anyone have any pros or cons about using the marine plywood and indoor outdoor carpet.
thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
