SWG Cell.
Just a quick newb question. I have the zodiac clearwater salt gen system. Initial pool charging was done over the last couple days. Pool store says everything is good, but I can't confirm till my taylor kit shows up. I have been running the system 24hrs a day at roughly 3 lights. 5 is the max I can run at. When it was put in the little fins the water passes through inside the clear plastic housing were black. I am noticing the edges are becoming very white. Its only been 4 days that it has been running. Is this something to be concerned with? Is this what they term fouling or something else? Any info would be appreciated.
Caustik
- You may not post replies
- You may not edit your posts
Forum Rules
