Results 11 to 12 of 12
Thread: New IG Vinyl pool with surface cracks and loose handrail????
    Honesdale PA
    Default Re: New IG Vinyl pool with surface cracks and loose handrail????
    Here's a pic of the thinggy that holds a rail tight. That wedge piece when tightened bears between the galvanized steel rail cup and the rail. To remove the rail you need to loosen the bolt a few turns, the wedge may not loosen, then give the bolt head a little whack with a small hammer to loosen the wedge. Rail should come out pretty easily then.
    Attachment 564
    Jul 2006
    Arkansas
    Thanks for the picture. I will show it to PB if he doesnt't repair the problem. Web
  1. Cracks in a new shotcrete pool
    By AZWldctFan in forum In-Ground Pool Construction and Repair
    Last Post: 06-04-2012, 06:55 PM
  2. Cracks in fiberglass pool
    By msehome in forum In-Ground Pool Construction and Repair
    Last Post: 01-29-2012, 10:49 PM
  3. Securing a handrail
    By Sumo1 in forum In-Ground Pool Construction and Repair
    Last Post: 11-26-2007, 12:47 PM
  4. Pool Light is loose
    By mrpbjnance in forum In-Ground Pool Construction and Repair
    Last Post: 05-31-2006, 09:47 PM
