Results 1 to 10 of 12
Thread: New IG Vinyl pool with surface cracks and loose handrail????
    Honesdale PA
    Default Re: New IG Vinyl pool with surface cracks and loose handrail????
    Not sure but my gut tells me the cracks are not right. As for the PVC for the handrail anchors....is that what you're saying? My rails sit in galvanized steel anchors. There are several pool builders as regulars on this forum and I'm sure they will kick in. For now...express your concerns about the issues, forcefully, and hold off on the final payment. Once you fork over the $$$ you may never see the PB again.
    Central New Jersey
    My deck is to be poured and the holders for the rails and ladder are galvanized
    Jul 2006
    ditto here too, thats a lot of stress that PVC will go under, I'm not sure thats what it was designed for. As for the small cracks... I think hairline cracks are normal for concrete decks, but anything that you can get a dime or quarter in is not normal.
    Waterworks is offline In the pool biz Thread Analyst Waterworks 0
    The handrail should certainly be set in galvanized, bronze or fiberglass anchors meant specifically to hold 1.9" O.D. pool rails and ladders, rather than PVC. These anchors allow you to tighten the rail so there is less movement, and are also stronger, i'm sure.
    Concrete cracks from time to time. I would wonder about my installers if a new pool had cracks in the deck that quickly. Even still, small hairline cracks do happen on even the best jobs from time to time. Canuck was right about the dimes and quarters; if the gap is that large, your builder should look after it.
    Brad
    Waterworks Pools
    De Soto, Missouri, USA.
    The anchors for the handrail should be down in the concrete- they put the pcs of pipe in them to keep them cleaned out when pouring the concrete- when done the pipes are pulled out and the handrail is set into the anchors. At least thats how they did mine. Check to see if they remembered to tighten the bolts that hold the handrail in place.
    Mike
    Jul 2006
    Arkansas
    The cracks are hairline cracks- very small- a fingernail file will not even fit in them. However, there are several of them.
    Yes, the pvc was pulled out. It looks like there are galvanized sleeves that the rails sit in. PB says that since we want a safety cover, the handrail could not be cemented into the deck. That is why it is loose. Supposedly we can take the handrail off. He says it is too late to make it tight and claims that he told us this before he started the pool. We don't recall the conversation. Can the handrail be stabilized at this point, without tearing up the deck? He says no, that he can only try to put wedges in, to tighten it up some.
    Tcap is offline ** No working email address ** Tcap 0
    Southern NH, US.
    Hi Web,
    We put in our vinyl pool last season, but didn't do the deck until about April of this year. We have no cracking at this point but it has only been one season. We will see what the winter brings. I'm not sure you should see cracks this soon if they settled the surrounding dirt correctly. Also, we have a safety cover and our handrails are solid in the galvanized sleeves. They can still take them out and tighten them back up when we put them back in next season.
    Good-luck!
