Advice for using aqualogic ps-8
Building our 2nd ig pool. Last pool used an intermatic control box with manual timers. (worked great)
I'm thinking of using an aqualogic ps-8 this time and have a couple of questions:
Does this unit serve as the main breaker box for all of the pool equipment? Can I pull 100-125 amp service to this box and have all the breakers and disconnects inside?
From all I can understand on the Hayward site, It seems that the unit will also serve as timers for cleaners, pumps and heat, with remote service for inside the house. Am I getting this right?
Finally, will the ps-8 do SWG with just the addition of a cell and probe? ( no seperate aqua-rite unit needed?)
Thanks for the continued help,
Cal
