More Questions ...
I have had the pool a couple of years now and last year was the 1st time I winterized it myself because the pool installer disappeared ! My 1st year winterizing just duplicated what the installer did but it did not seem to give complete protection. (Was lucky last year in my opinion) You response shows knowledge of the issues involved and I appreate the detailed help. Now for the additional questions:
1. My spa jets get removed by pushing a tab towards the center and then pulling the whole assembly out. You can't screw a plug in so I am assumming the # 11 Plugs are the rubber with wing nuts to expand.
2.When the spa was installed they screwed something up with the "Fill Fitting" by the steps and installed a fitting in it's place that is non adjustable that just rotates around by itself. Is there supposed to be a special fitting there ? I am unsure how this one comes out ...
3.I use a compressor fitting on the pump filter drain. What psi should I be using ?
4. If I refill the tub do I need to put anything in it like the skimmer to prevent cracking or is the area large enough to prevent it by itself?
5. Is RV anti freeze the dsame as Pool antifreeze ? I notice a big differance in price ...
Thansk again !!
