Results 1 to 8 of 8
Thread: 25PPM super shock
    Exclamation 25PPM super shock
    OK! Here we go.
    I've battled this algae long enough!
    I poured 4 gals of 6% bleach in my 10,000 gal. pool.
    With a CYA level of 40PPM my level should be 15PPM but I will be going to 25PPM CL. I plan
    on brushing and pouring in a gal each evening till the crap is gone from the bottom.
    Anything I should know?
    I will keep you posted
    Thanks matt4x4
    Indiana.
    Default Re: 25PPM super shock
    What kind of pool? 25 is fine, but may bleach your liner if it's vinyl.
    Above ground vinyl. Approx. 10,000 gal.
    I will take the risk of fading the liner, the sun has done this already and it's only 3 months old. Florida sun you know.
    Exclamation Re: 25PPM super shock
    update!
    water looks a lot better, still a little cloudy. Small amount of the "stuff" this morning I added another Gallon of 6% and swept the pool. Stopped by the house at lunch-time, water test the best I could tell buy deluting the sample was 20 PPM. So I added another gallon of 6% and installed the Baracuda and let it run till I got home about 4 hours. I will re-test the CL this evening and add if needed.
    Darrell W. -------------------------------------------------------------------
    Man!,this water is cold!
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Update #2
    Just got home this evening and the pool water is crystal clear! My PH was a little high 8.0 so I added 1 cup of acid to bring that down, the total chlorine level is about 5PPM but the free chlorine is about 10PPM is this a problem.
    9,240 Gallon
    Daytona Beach,FL.
    Go back and measure again...total chlorine = free chlorine + combined chlorine, so total can't be 5 if free is 10.........
