I
No idea on what level of nitrates is bad. I know that it's food for algae, but don't know what level starts to trigger significant algae. Perhaps someone else knows that.
Richard
From what I have been able to find out it seems to be between 10-25 ppm but I don't know if that is as nitrate nitrogen or nitrate ion which is approx. 4.4 times higher than the nitrate nitrogen reading. I suspect it is the nitrate nitrogen reading since this is the way it is most commenly expressed in water quality measurements. The EPA has set the safe limit of nitrates in drinking water at 10 ppm nitrate nitrogen (44 ppm nitrate ion). Some sources state that superchlorination (well above breakpoint, in ther neightborhood of 50 ppm and often much higher) often effectively deals with high levels of nitrates and nitrites in the water. Others say that there is no way to reduce high nitrate levels besides a drain and refill with low nitrate water.
When nitrates are present in the water nitrites are often present too and the effect of both are cumulative in terms of algae growth. Nitrites are tested more rarely than nitrates in pools.
