You can also use a metal sequesterant (like Jack's Magic) and lower your PH - sometimes that will lift a stain without the absorbic acid - but some experts (like mbar) can help you better.
Also - you want to get your fill water tested for copper and iron and probably keep some sequesterant in the water to prevent this in the future. Good luck!
