Results 1 to 10 of 11
Thread: Pool Opening Pics
    Birmingham, AL, USA.
    Default Pool Opening Pics
    To better illustrate my point and to visually answer my earlier post of what happens when you leave a loop loc cover on in 80+ degree weather. The first two are right after I took off the cover. The last two are after five days of bleach and filtering 24 hrs a day. The water is still a little cloudy as you can barely see the drain and the Polaris. I may try a little super blue clarifier to see if I can get it back to crystal clear.
    http://i3.tinypic.com/vsgwmd.jpg
    http://i3.tinypic.com/vsgx8h.jpg
    http://i3.tinypic.com/vsgxgz.jpg
    http://i3.tinypic.com/vsgxmf.jpg
    Illinois.
    Thumbs up Re: Pool Opening Pics
    From pond to pool in 5 days! Thanks for the pics. Very interesting. Hope mine looks better than that when I open it next month.
    Default Re: Pool Opening Pics
    Actually it took seven days to get it crystal clear the pics above were after about 3 days and the water was still abit cloudy. Now it is crystal clear.
    Howell, Michigan
    How high did you run your Cl during the 5 days?
    Thanks.
    I tried to Keep the FC between 10 and 15 just using bleach. If you keep it at that level it shouldn't take long to clear. After few days as it begans to clear I added a little liquid clarifier to help the new sand in the filter catch all the tiny particles that didn't get caught the first time thru the filter. The pics above are actually quite cloudy compared to what it looks like now. Now it is crystal clear.
    http://i3.tinypic.com/wbox9g.jpg
    http://i3.tinypic.com/wboynt.jpg
    http://i3.tinypic.com/wboyt4.jpg
    Wink Re: Pool Opening Pics
    And who says bleach doesn't work? The proof is in those pics! Great job and nice pool. Enjoy!
    Watermom
    UUGH!
    Procrastination really doesn't pay - EVER!!!
    Pool was crystal clear a month ago....well, dirt and some leaves on the bottom, but other than that it was clear...
    A week before easter, I said to myself - gotta go buy bleach and get it in there, temps are rising....
    Easter we were away...
    A week after easter, I said it again....
    I finally bought a bunch of bleach, set it in the garage and forgot for 3 days
    When I went to put it in, it was green just like above....
    Oh well! still too cold to swim anyways, should be clear by next week!!!
    Indiana.
    Don't you know you can't use bleach in a swimming pool?
    Now for fun take those pictures to the poolstore and show them the before and ask what to buy. Then show the after and tell them how you cleared it up.
    Service Guy is offline ** No working email address ** Service Guy Not to be trusted
    S.E. PA
    Quote Originally Posted by JohnT
    There are byproducts and fillers in bleach that really shouldn't be in pool water and can wreak havoc on pH & alkalinity. Regardless, when attempting to clear a mesh covered pool in the spring, the MOST important thing is filtration. Without adequate filtration, you can dump all the bleach (or other sanitizer) you want in the pool and it's not going to make a big difference. One way to keep the pool from getting to such a nasty state, is to put a floating chlorinator in it when the pool is winterized. Periodically check & refill throughout the winter and even add additional algaecide if needed. If you religiously do this, without procrastination, then chances are your water will be clear when you remove the cover and save you days or weeks of clean-up time. The other option is to buy a SOLID VINYL COVER! Your water will look the same in the spring as it did when you winterized it.
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    "There are byproducts and fillers in bleach that really shouldn't be in pool water and can wreak havoc on pH & alkalinity."
    huh??
  1. How to fix the rust in pool metal walls!? [pics included]
    By Ccuello in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2013, 11:39 PM
  2. New user looking for above ground pool reviews, ratings n user pics of pools
    By Piggiesinlove in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2011, 06:08 PM
  3. Pool Progress Pics
    By wbrady in forum In-Ground Pool Construction and Repair
    Last Post: 09-20-2006, 09:04 PM
  4. Here's my pond to pool pics using just bleach
    By rockg in forum Dealing with Algae & Slime
    Last Post: 07-26-2006, 08:27 AM
  5. Oval Pool Set up with pics and tips?
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 05-02-2006, 11:30 AM
