Results 1 to 10 of 11
Thread: Replacing liner and water
    Default Replacing liner and water
    I am fixing to replace me liner. my pool holds 22,000 gal of water. my question is when i fill my pool back up with water do i need to add hardness, or can i just add bleach and baking soda ?
    Indiana.
    Default Re: Replacing liner and water
    What you need to add will depend on your fill water. If you will use your tap water, just let it run a minute and draw some for a water test. That will tell you where you'll be when you fill the pool.
    In a vinyl pool, you don't need to worry about the hardness. However, you do need to test for pH and TA to see what to add. And you will have to add stabilizer as well.
    What is TA if you mind me asking
    nc.
    TA= Total Alkaninity
    Margit
    Oops, sorry......Total alkalinity
    nc.
    soooooooooooorrrry about the Typo
    Of course it's Alkalinity
    nc.
    LOL
    Thanks Janet
    Margit
    LOL You and I just posted at the same time--didn't see the typo until after you mentioned it
    If you are not familiar with Total Alkalinity, don't be confused by the name--it's a buffer that prevents pH from deviating too much. Suggested amounts are between 80 and 125, but with vinyl you can safely go to 180 without having to worry about lowering it.
    Hardness is calcium and NO MATTER WHAT THEY TELL YOU, you don't need it in a vinyl pool. Calcium's job in water is to prevent the calcium in the walls of concrete and plaster pools from being leeched out, weaking the concrete, mortar or plaster. It has no effect on vinyl or fiberglass pools.
  1. replacing liner need some suggestions
    By poolhelp101 in forum In-Ground Pool Construction and Repair
    Last Post: 03-01-2013, 05:08 PM
  2. Replacing liner with high water table
    By jjdean in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2011, 07:14 PM
  3. Replacing liner soon
    By kjmelak in forum Above-Ground Pool Construction & Repair
    Last Post: 05-09-2009, 12:09 AM
  4. Replacing a liner
    By TimWillin2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-23-2007, 11:10 AM
  5. Emptying water before replacing liner
    By CathyOh in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2006, 12:18 AM
