Thread: Pump too large for my system?
    San Antonio, TX, USA.
    Default Pump too large for my system?
    I have a 10,000 gal inground gunite pool, attached overflow spa, 100 st ft Hayward cartridge filter, 2” pvc throughout, 2.0 hp 2 speed pump motor. I feel that the large size of this pump is not only inefficient but also contributing to poor filtration.
    Without going into a long winded story, I am unhappy with the quality of the filtration in my pool. I have spent many $$$ replacing cartridges ever 6 months, and even tried adding some synthetic DE to the filter. All with little or no effect.
    Am I correct in assuming too large a pump motor in a cartridge system can cause the filter pores to widen and thus decrease the filtering efficiency? If so, I guess I’ll be looking for a new pump. If that’s the case, what size would I need, 2 speed preferred. Are there any brands or models that would be better than the rest or any I should steer clear of?
    DerrikM
    Sugar Land, Texas
    Default Re: Pump too large for my system?
    First, your post doesn't match your signature.
    Does that pump also feed your spa jets?
    If not, I think a two-speed 1 hp would be more than enough - possibly even a two-speed 3/4 hp.
    If it does feed the spa jets, you'll have to provide some information on the number of spa jets.
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
    Quote Originally Posted by eljefe281 View Post
    Thanks for the heads up about the signature. Yes this pump feeds the 5 jet spa as well as the pool. However we really don't use the spa at all. Plumbing is set up with a 3 way valve so I can regulate flow to my liking.
    DerrikM
    Sugar Land, Texas
    I believe the 1 hp or 3/4 hp two-speed would be plenty, but I think it would be a good idea for you to wait for some of the more experienced members on the board to chime in.
    As far as brands are concerned, I guess any of the major names are good - Pentair, Hayward, Jandy.
    I am getting Pentair pumps.
    If you call Pentair tech support, they will help you select a pump. I imagine that's true for any of the other companies as well.
    Sugar Land, Texas
    Basic steps for selecting a pool pump:
    How many gallons of water do I need to turn over in one day? (Twice your pool volume)
    How many hours per day will I run my pump? (Entirely up to you - 8-12 is typical)
    Flow rate required = (gallons) divided by (hours) divided by (60 minutes per hour) = gallons per minute
    Assume a system TDH of 45-65 feet. If your circulation system has a lot of valves in it, a lot of piping elbows, and/or a long run from the equipment to the pool, choose a number on the higher end of that range. Make your best guess. (It should be noted that this is a shortcut, but one that is fairly well accepted by the board).
    Look at the pump curve for a particular pump you are considering. How much flow will it deliver at the TDH you selected? Compare that to the flow rate required you calculated above.
    Note that two-speed pumps will have two pump curves, usually on the same graph. At low speed, use a TDH approximately one-fourth (25%) of the TDH you selected above. Look at the pump curve for a particular pump you are considering. How much flow will it deliver at the TDH you selected? Compare that to the flow rate required you calculated above.
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by derrikm View Post
    Just curious as to why you simply don't run your pump on low speed all of the time. It is oversized at 2 HP but on low speed, it should be fine.
    Mark
