Results 1 to 8 of 8
Thread: Do pools need drains?-A study on the subject
    OK
    Default Re: Do pools need drains?-A study on the subject
    We installed a 13 x 30 fiberglass pool on a do-it-yourself basis in '05. We decided not to install a main drain since the pool will never be drained anyway. We didn't want to worry about it leaking or entrapment.
    As far as circulation goes, there are 2 inlets in the shallow end and 1 in the deep end which keep things pretty well stirred up. It needs vacuumming 3 or 4 times a week, which is about par, I suppose. 1 skimmer in the deep end is all that feeds the pump. There is a sump line under the pool to pump out ground water if it should need to be drained, a submersible pump could empty the pool fairly quickly.
    Hindsight being 20/20, I wonder if I should have some sort of vacuum breaker in case the vacuum hose gets blocked?
    Katy, TX
    Cool! That's a really nice, peaceful setting for your pool.
    Michael
    Cedar Hill, TX (Dallas)
    How likely is entrapment with modern drains?
    I have two wall drains plumbed to my main drain to prevent such a thing. (even in the spa) You'll need help or really work at it to get entrapped!
    Robert
    South Florida
    I can't say it's not possible because anything you can think of is, but you would have to work pretty hard at it to get intrapped. The antivortex covers are screwed down so that a screwdriver is needed to remove them and are solid on top so the water flows in from the sides only. Pretty difficult to cover that.... Now you have two of those 3' apart. So it would either take a 4' wide person, or someone would have to lay accross both of them to try and cover the openings on the perimeters of the drain..... or..... it would take two people to do so at the same time.
    Oh... now some states are requiring a vent line attached to the suction line in addition to the two MDs in the event the almost impossible scenario I described above happens.
    Any thoughts or comments on this??
    Zina
    Pool-Design . net
