Thanks, I guess I did overlook it.
Not sure you will get an even color with acid staining your already blotchy concrete, Unless you have your PB spray a cementious overlay first.
My Pool -> http://www.zacharen.com
You have a beautiful pool, Yomanda. As for acid staining, one feature that I like is the final color does not have be even, and can be a combination of colors. We had the PB replace a portion of our driveway, and we would test the stain on it, before using on the pool deck. We are hesitant to put down a topping, and that is one reason acid staining seems appealing. Thanks for your input.
After you acid stain your concrete, it will have a 'dull' color look to it. That is why it will be necessary to use a good sealer to bring the color out. http://www.scofield.com/ And yes you are correct with the different color acid stains giving your concrete a more textured look to it. I'm sure acid staining will definitlely be your best solution.
http://acid-stain.com/messageboard/messageboardhome.asp
Thanks for your comment Webfeet.
