Re: Polaris 65 problem - please HELP
well............. we took the Polaris apart to troubleshoot as described in the Manual on Page 6. We do have enough pressure (12-14 psi )BUT the turbine inside the mechanism is not turning and doesn't go back and forth as it should be. The little ball is moving around as it is suppose to but the turbine just won't move!
any ideas?????
thanks
Sissy in GA
16x28x4 AG Doughboy
