Results 1 to 10 of 11
Thread: Liquid Stabilizer
    Default Liquid Stabilizer
    I went to Leslies to pick up some CYA for my Salt Water pool... and they were trying to sell me the new liquid CYA... and while it's tempting... I read the ingrediants I didn't see cynauric acid, so I passed on it... the regular granual CYA is such a pain to get disolved. ANyone see this new liquid CYA, or what is your tip for disolving the CYA? I put warm water in bucket, and keep mixing it, then spoon it into skimmer a little at a time... it takes a while to disolve.
    Default Re: Liquid Stabilizer
    I just add mine via the skimmer and don't backwash for a week or two....
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    I saw someone else on here say they put their CYA granuals in a sock in the skimmer (I'm assuming they tie an knot in the open end of the sock )and let it slowly disolve that way. That sounds like a good idea...especially if you do anticipate having to backwash during the CYA add process. (I have to backwash after every time I vacuum due to the large amounts of sand that blow into my pool because I haven't gotten sod put down around it yet.) (Edited because apparently I can't put together a coherent sentence today.)
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Quote Originally Posted by Sherra
    (I have to backwash after every time I backwash due to the large amounts of sand that blow into my pool because I haven't gotten sod put down around it yet.)
    I've re-read that sentence 4 or 5 times, but I still have no clue what you were intending to say.
    Quote Originally Posted by bethsg
    Can you provide an exact product name, and list of ingredients? If there's a patent number, that should help too.
    They don't have it listed on their website.
    But, I've learned the hard way, that it is generally very wise to avoid "NEW" pool chemicals. Most of them turn out to be "BAD" pool chemicals.
    Ben
    Quote Originally Posted by PoolDoc
    That's because I typed that sentence at work and typed it wrong...I meant to say that I have to backwash after every time I VACUUM...duh...sorry...I'm easily distracted.
    Sherra
    Mandeville, LA, USA.
    Sherra, You should be able to vacuum to waste instead of vacuuming and then backwashing. Same end result.
    I feel like I'd be wasting way too much water that way though...it takes me 15-20 minutes to vacuum (I go very slowly - I'm a perfectionist about it) as opposed to backwashing until the water runs clear (usually 90-120 seconds) then rinsing. and
    Sherra
    Exclamation Re: Liquid Stabilizer
    Ben
    Ben,
    NaturalChemisty (the enzyme and phosphate remover people!) is selling a liquid stabilizer but you have to email them for the MSDS (as for all of their product line!) and it has not been approved for use in California.
    Here is a link:
    http://www.naturalchemistry.com/Pool...?idProduct=197
    They claim it is not an acid but a salt and has a pH of about 8.
    I wonder about this product myself. It is the only liquid stabilizer I have ever seen. Perhaps this is the one being referred to in this thread?
    WaterBear, that is the exact product they tried to sell me... I recognize the bottle...I didn't see the words "cynauric acid" anywhere, so I said no thanks... I will patient and add my cya slowly but surely....
  1. Liquid CYA!
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-05-2011, 11:07 PM
  2. Liquid Stabilizer
    By bethsg in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-15-2009, 06:24 PM
  3. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
  4. HTH Stabilizer
    By let_her_flicker in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2006, 07:57 AM
  5. Liquid Stabilizer
    By b2001 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 07:08 PM
