Results 1 to 10 of 11
Thread: Liquid Stabilizer
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: Liquid Stabilizer
    I saw someone else on here say they put their CYA granuals in a sock in the skimmer (I'm assuming they tie an knot in the open end of the sock )and let it slowly disolve that way. That sounds like a good idea...especially if you do anticipate having to backwash during the CYA add process. (I have to backwash after every time I vacuum due to the large amounts of sand that blow into my pool because I haven't gotten sod put down around it yet.) (Edited because apparently I can't put together a coherent sentence today.)
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Quote Originally Posted by Sherra
    (I have to backwash after every time I backwash due to the large amounts of sand that blow into my pool because I haven't gotten sod put down around it yet.)
    I've re-read that sentence 4 or 5 times, but I still have no clue what you were intending to say.
    Quote Originally Posted by PoolDoc
    That's because I typed that sentence at work and typed it wrong...I meant to say that I have to backwash after every time I VACUUM...duh...sorry...I'm easily distracted.
    Sherra
    Mandeville, LA, USA.
    Sherra, You should be able to vacuum to waste instead of vacuuming and then backwashing. Same end result.
    I feel like I'd be wasting way too much water that way though...it takes me 15-20 minutes to vacuum (I go very slowly - I'm a perfectionist about it) as opposed to backwashing until the water runs clear (usually 90-120 seconds) then rinsing. and
    Sherra
