Results 1 to 10 of 24
Thread: How much is the TDS increased if Borax is added to 50 ppm
    Dec 2005
    Honolulu, Hawaii.
    Default Re: How much is the TDS increased if Borax is added to 50 ppm
    Chem Geek,
    Will do, have backwashed it once for two and half minutes of whitish-grey powder. Patience you say don't you remember I am half-German, that word is not in our vocabulary
    Getting dark in an hour so will pump up the chlorine and check in the morn. Hope that it will be the same; if it is, sell Wal-Mart's stock, as I will not be shopping there for a while!
    Aloha
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    Richard, thanks for the pointers on the spreadsheet. I presumed it would be complex, but your very lucid explanations of what seems to be happening with pool water has rekindled my long-lost chemistry interest (lost after too many late evenings studying for quizzes). I'll use at my own risk!
    smallpooldad, I've found that directly applying (rubbing/scrubbing) tri-chlor onto black algae patches seems to work quite well. And I've been using a stainless steel brush on mustard algae with good success also; the stainless brush seems to work better than a synthetic bristle brush.....but just my experience.
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
    Dec 2005
    Honolulu, Hawaii.
    Catnip,
    I agree a stainless steel brish works better.
    Aloha
    Dec 2005
    Honolulu, Hawaii.
    Well it was not black or mustard algae.
    Chlorine remained stable over night, for 3 days, at 40 ppm, pumped it back up to 40 ppm every night for 3 nights. So me thinks maybe adding Yellow Treat (Sodium Bromide) will do the trick, as these two types of algae are thought to be chlorine resistant.
    Added 5 oz of Yellow Treat and pretty much nothing happened. Chlorine got used up and went down to 30 from there it has been a very slow descent to 12 ppm of chlorine. At 12 ppm of chlorine last night and 12 ppm chlorine this afternoon at 3 pm, it has been very overcast and humid today and yesterday.
    The stains were primarily lightened when I initially added Borax, and then when I scrubbed with a wire brush. However, since then really no change still some light stains in the plaster maybe from 9 years of not knowing the Pool Forum. Why did you not call me in those 9 years?
    The Borate is around 70 ppm and this is why the chlorine stubbornly refuses to go down any faster. What are your opinions?
    If that is the case, I will report back, and then maybe Chem Geek you have found the answer to controlling chlorine use.
    Chem Geek, if this is true then be careful if you see any guys dressed in black suits with violin cases and wearing a yellow Wal-Mart smock!
    Finally the pool is crystal clear, clearer than it has ever been.
    Here are the figures:
    Cl 12 ppm
    Alk 80 ppm
    pH 7.4 ppm (seems to be stuck at this number/has not moved for days and yes I neutralized the chlorine for a good reading)
    Calcium 350 ppm
    CyA 50 ppm
    TDS 740 ppm
    Aloha and thank you one and all.
    Dec 2005
    Honolulu, Hawaii.
    Now I'm worried, just read your other reply on the TGT Debate stating that bromide never goes away. If this is so why is the Chlorine holding? Or, is it possible the bromate can get eaten up?
    Looking forward to your reply.
    Aloha
    Bromide (and bromates) and Borates are two completely different things. You have Borate, Boric Acid, Borax or Boron (take your pick as all terms could be used) in your pool, not Bromide or Bromates. I know this is confusing -- just focus on the first three letters -- Bor... is the stuff that helps prevent and kill algae and helps stabilize pH (and makes the pool sparkle) while Bro... is the alternative sanitizer to chlorine, often used in hot tubs, and should not be used in a pool unless you permanently want your pool to use Bro... (i.e. you have to drain your pool to remove Bro...).
    The high level of Borates in your pool will help prevent algae and kill some of it as well. That means that the chlorine won't have to so chlorine usage will be less because of it, at least in terms of killing new algae. However, the chlorine will still try to oxidize the algae that is there even if much of it is dead and could get somewhat consumed because of that. If you find that it isn't dropping, then the algae is dead and the easy-to-oxidize stuff has been taken care of so all that is left is to filter out the dead solid cells and you are done. It sounds like your water finally turned clear so that's that!
    As for recommending anything different than chlorine, I would say that isn't true. Though the Borates (Borax) may have helped speed up the killing of the algae, the decision to use Borates is a yes/no decision for whether you want your pool to always have borates or not. You cannot get rid of the borates in your pool except by dilution (not that you'd want to get rid of Borates as they generally do no harm, but I suppose if you built up more than 100 ppm you might want to dilute to cut back). So using Borates isn't something to tell people to do when they have an algae problem -- it's a separate decision and yes, if they already decided to use Borates then it appears that they will have less problems with algae.
    And yes, using Borates reduces chlorine consumption (as waterbear found to be true), but that won't put Wal-Mart out of business. You'll just need to buy less chlorine...I'm sure Sam's folks will find other things to sell to you.
    Richard
    Dec 2005
    Honolulu, Hawaii.
    Thank you for your reply.
    In the last message above I should have typed "is it possible the bromide", sorry for the confusion.
    Until Wal-Mart sells "Marmite", Britain's gift to the culinary world (Vegemite in Australia) I will not be going back, except for chlorine.
    But I did put Yellow Treat 4.5 oz (Sodium Bromide) in the pool. Will this, or has this gone away, due to the large amount of chlorine I used? Or do I have to drain it? Please say no.
    Lastly I will not add any more Borax (Borate) to the pool until it shows 50 ppm. Now have the AqauCheck test strips, they arrived two days ago.
    Aloha from a hot and humid Hawaii that only the mosquitos could love today.
    Dec 2005
    Honolulu, Hawaii.
    Added 4.5 oz of Yellow Treat and pretty much nothing happened. Chlorine got used up and went down to 30 from there it has been a very slow descent to 12 ppm of chlorine. At 12 ppm of chlorine last night and 12 ppm chlorine this afternoon at 3 pm, it has been very overcast today and yesterday.
    The Borate is around 70 ppm and perhaps this is why the chlorine stubbornly refuses to go down any faster. What are your opinions?
