Thread: Clog after vacuuming
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    Default Re: Clog after vacuuming
    Have you tried using the main and skimmer inputs to the pump one at a time (presuming you are plumbed with valves to do this)? If you can't get flow with any of those inputs, if would almost certainly point to a clog or vacuum leak somewhere upstream of the valves.
    Though it sounds like you have eliminated the possibility of a clog in the suction line(s) between the skimmer(s) and the pump, let me pass along a solution I used when I managed to clog my skimmer suction lines with wood chips from the surrounding landscape. The main drain was working fine, so I could get flow through the pump, just not from the skimmers.
    I plumbed in a tee in each suction line just before the shutoff valve. I then connected the output hose from my Polaris booster pump to the tee fitting and (after closing the shutoff valve) used the water pressure from the Polaris pump to blow out the suction lines in the reverse direction, i.e. back out the skimmers. It worked like a charm. I then plugged the tee's and left them in place in case I get any future clogs.
    I've seen pool service companies do something similar by connection the suction side of a portable pool pump to the skimmer inlet and sucking out the blockage.
    Good luck!
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
