Results 1 to 10 of 14
Thread: Swimming Pool Acid
    liz+3 is offline ** No working email address ** liz+3 0
    Humble, TX
    Default Swimming Pool Acid
    Hello all,
    I just purchased some Kem-Tek swimming pool acid for lowering pH. The label indicates it is 38.5% sulfuric acid. I didn't realize the label did not say muriatic acid when I bought it. I purchased the acid at a discount store - 6 gallons for $9.00 - closeout price - bought the last 6 gallons!
    I have been using muriatic acid (HCL) for lowering my pH. Can I use this Kem-Tek product even though it is sulfuric and not HCL acid or did I just waste $9?
    Thanks.
    Liz
    15000 gallon IG Gunite with Diamond Brite (3.5 - 5 - 3.5)
    7 Ft. Diameter Raised Spa with Spillway
    Intellichlor IC20 SWCG
    Intelliflo 4X160 Pump
    60 Sq. Ft. DE Filter
    Spa Heater
    Jet-Vac
    Default Re: Swimming Pool Acid
    You can use it. The only downside is that you will add to the sulfates in your water. You also end up adding sulfates when you use non-chlorine shock (potassium monopersulfate or KPMS). This is not a problem unless the sulfates get really high at which point it starts to affect water chemistry a little bit (makes the water more corrosive and less likely to scale), but it would take a heck of a lot of sulfates to cause that so I wouldn't worry about it (300 ppm of sulfates would be equivalent to lowering the pH by 0.1). Just get Muriatic Acid whenever you run out of this stuff.
    As for how much to use, it is very close to the Muriatic Acid in effective acid concentration per volume, though you can verify this by looking at the bottle to see how much it says to use to lower pH. Though sulfuric acid has two hydrogen (H2SO4) compared to hydrochloric acid (HCl), it is more than double the molecular weight so this along with the 38.5% vs. 31.45% cancels out (I suspect they chose 38.5% concentration so that the acid was close to the 31.45% Muriatic Acid concentration).
    One cup of sulfuric acid in 10,000 gallons adds 5.9 ppm of sulfates so it would take a whole lot of acid before you started to see any impact from the sulfates. One cup of non-chlorine shock (KMPS) adds 5.1 ppm of sulfates so is about the same in that effect.
    Richard
    Humble, TX
    Thanks Richard.
    Glad I didn't pass up a great deal.
    Liz
    Spa Heater
    Jet-Vac
    It's not that great a deal--ultimately continued use can give you problems that hydrochloric acid won't.
    What Chem_Geek is basically saying is it's OK to use it, since you have it, but you have to watch for things building up, unlike Muriatic Acid.
    I would not buy it again, though.
    It has about the same side effects as using dry acid (sodium bisulfate) without the convienence factor. With a SWG, hydrochloric acid (muriatic acid) is my first choice.
    Edit: Muriatic acid adds chloride ions to the water so the salt (sodium chloride) that the SWG uses is 'reformed' after generating chlorine. Sufuric acid and dry acid do not do this. (Richard, I know this is very oversimplifed and not totally accurate but it is close enough to the correct annswer without getting too technical). As Carl said, it's ok to use but when it's gone you would be better off with muriatic acid in my opinion.
    Humble, TX
    All right, you all said it is OK to use but I should watch out for things building up in the pool (ie: sulfates). So, if I use these 6 gallons of sulfuric acid over the next couple of months, how much "stuff" will build up in my pool and should I be concerned about this buildup? Is there any way to test for the sulfates?
    Based on the respones, I am highly considering not using the sulfuric at all - that way I won't have to worry about sulfates.
    I also will never again buy anything but HCl for my pool!!
    Thanks,
    Liz
    Spa Heater
    Jet-Vac
