Results 1 to 10 of 15
Thread: Best way to clean a CARTRIDGE FILTER?
    west1745 is offline Registered+ Thread Analyst west1745 0
    Dec 2005
    Default Re: Best way to clean a CARTRIDGE FILTER?
    Quote Originally Posted by CarlD
    Hire someone ELSE to clean it!
    Zina's absolutely serious. It's non-sudsing and seems to be well-documented.
    There's a trick I've read about: You need 2 cartridges. Someone sells PVC canisters that you slide the filter into, add water and Cascade, then close, seal and forget about. When the one you are using is dirty, you pull the one out of the canister, hose it off, pop it in. The dirty one you hose it off a little, slide it into the canister with fresh water and Cascade.
    I don't know where you find these canisters--a Google search may help.
    Does anyone know where you find these canisters or what they are called?
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    I would love to know where to get these too. I have the largest Clean & Clear Plus cartridge filter and to soak the cartridges requires me to use a 30 gallon garbage can and soak 1/2 at a time. Then, there are 4 cartridges. What a pain!
    Could someone post the "recommended" proportion of Cascade and water?
    I've never soaked my cartridges, just hosed them off. And what an ugly job. I could rinse those things for 100 hours and they would still give off dirt. They're like 4 of those big brown Easter Island statues, just sitting there looking at me. And my psi is not that much better after re-installing! I'm obviously willing to try something else.
    Peace,
    Paul
    Quote Originally Posted by kearpaul
    Once cup per every 5 gallons water
    Hope this helps.
    Thanks, Waterbear.
    I'm off to try the Cascade solution right now. Gonna use my new big recycling cart. That should hold two filters.
    Cheers,
    Paul
    The fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, and they laughed at the Wright brothers. But they also laughed at Bozo the Clown.
    Carl Sagan
