Re: Skimmer plug got sucked through and is stuck
Scottsdale / Shea rentals has rental pumps for 30.00. Get one of those to finish the drainning process. If water is still getting past the plug, will it be an issue if it's left in place once you refill the pool ? Is there enough volume getting past it ?
