Thread: raising alk
    Jul 2006
    Default raising alk
    Here are my spa results
    bromine 6.40
    pH 7.5
    hard 190 ppm
    alk 50 ppm
    how do I raise my alk? I know the steps to reduce.
    The pool company suggests spa life buffer.
    Default Re: raising alk
    The pool co probably makes $$$ off of 'spa life buffer' (but it's the same thing as ... baking soda ). They may market as 'sodium hydrogen carbonate' but it's chemically equivilent (for the buffer) as baking soda (sodium bicarbonate), they may add some scent or dye to perfume and color your pool, but the buffer is 'baking soda'. In a spa, the amount added to raise is measured in tbs. rather than lbs. , but the chemistry should be the same
    Jul 2006
    Thanks, baking soda it is!
  1. Raising pH level wihout raising Alkalinity
    By JMannWV in forum Dealing with Alkalinity and Calcium
    Last Post: 08-01-2012, 12:28 AM
  2. Raising PH
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-08-2006, 12:50 PM
  3. Help with raising ph
    By ccc in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-15-2006, 05:42 PM
  4. raising alk?
    By dhale63 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-16-2006, 05:57 PM
