Get a new electrician. 2005 NEC Code requires:
There is no mention in the NEC of paver decks being exempt. Unless the pavers are bonded, you will be at risk of stray voltage issues. I have seen pools with stray voltage issues that had concrete decks with fiber reinforement and no rebar. The bad part is that there is no good way to bond paver decks, and my first inclination is to advise against them until a solution exists.The equipotential bonding grid shall cover the contour of the pool and the pool deck extending 1m (3 ft.) horizontally from the inside walls of the pool.
