Am following the directions on the sticky's for above ground closing. Yesterday morning I added the Polyquat algaecide after having had up to shock level up til the night before. When I added the polyquat I changed the multiport valve to circulate rather than filter.
As tempertures are supposed to dip tonight I am not going to start lowering my water as I had planned, I will do it during the day on Friday
Tonight my plan is to bring the chlorine back up to shock level as it has dropped significantly after adding the polyquat. My question is should I switch the multiport back to filter at this point, or is there still danger that it will filter out the polyquat?
My water readings are:
FC: 6
CC: 0.5
TC: 6.5
pH: 7.6
TA: 200
Hardness: 300
Using the bleach calc my plan is to add 4.2 gallons of bleach tonight.
thanks,
John
