Re: PVC piping
Poconos,
Thanks for the photo. I'm just trying to get an idea of how folks have converted the typical hose and clamp setup to a PVC pipe setup. I guess I'm interested in seeing every aspect of how the PVC fits into their systems and whether they have had any unforseen problems so I can plan for my own for next spring.
You said you still use hose and clamps to lessen the stress on the threaded joints. Any problems with clamps? Did you try all PVC at one point and have a problem?
I've had 3 separate incidents where the clamps let loose and the set up sprung leaks; two minor, one a whopper. I also have a slow leak at the connection between the pump and the hose leaving it to the filter. I temporarily "fixed" that with plumber's putty but I know it's not a permanent fix.
CB
Re: PVC piping
CB,
I inherited the pool in 97 when I bought the house and had a pool company come in and redoo everything...plumbing, equipment, liner. Was all shot and I knew nothing about pools then. They hard plumbed everything together which is the cheapest and quickest way but you can't take anything apart without cutting pipe. Later I redid the above ground plumbing myself and added the hoses. The auto radiator hoses are relatively soft and I don't have leaking problems. On one pressure line I do have two clamps though. It turns out 1-7/8 radiator hose is a good fit for 1-1/2 PVC pipe. The hose does tend to stick to the pipe and doesn't want to crack loose easily but a thin screwdriver pushed in to break the seal a little and then a pair of channel-locks on the hose will break it loose if you can't do it by hand. Makes it easy to remove the valve assembly for the Winter.
Re: PVC piping
Sorry it's taken me awhile to respond. Thanks for the photo and the tips. If I understand you correctly, in addition to the PVC pipe, you are also still using hoses and clamps for part of it. Am I correct? Have you had any problems with them. You mentioned "pressure hose". Which one would that be? They all seem to have some amount of pressure behind them from my experience.
Thanks.
CB
Re: PVC piping
Here's mine. It's very easy to use PVC. Poconos uses auto radiator hose, but I don't know how that holds up to sunlight and UV. I use TigerFlex, which is a flexible form of PVC. In the picture below, the horizontals from the filter are PVC, and the vertical to the pump and the hose-like piece are TigerFlex. Use Schedule 40 fittings on both.
I can roll up the T/F at season's end.
Re: PVC piping
Thank you again CarlD. Is Tiger Flex something that I can get at Lowe's? They'll know what I'm asking for?
Do the fittings to the pump & filter just screw on and off?
CB
Re: PVC piping
Very nice setup ....very clean.
Bob-
Re: PVC piping
The pressure lines I am referring to are the lines on the output side of the pump and filter as opposed to the skimmer or suction line. I likewise don't know how the hoses hold up to UV as they are inside a poolhouse but I would suspect pretty well. They are tough and reinforced because under a hood they have to handle probably 260 degree water at 15 psi pressure.
