Closed Thread
Results 1 to 10 of 11
Thread: quick question-closing now
    Default quick question-closing now
    have inground pool
    have drained below the skimmer and trying to drain below the returns
    i can't get enough pressure to drain much more...lacks about 2 inches being below the returns. do i need to get it below the returns and how can i get more pressure to do that? thanks
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    Default Re: quick question-closing now
    There is no indication of where you live. How deep does the frost go down in a normal year where you live?
    I'm in Central PA and have never drained the pool down or blown the lines.
    The returns are approximately 2 feet below the pool copeing and the skimmer boxes are down about a foot. I just put Gizmos in the strainer baskets drain and remove pump & filter then cover with a LoopLoc cover. This will be year #5 doing it this way.
    If you need to drain below the return, this works well for me:
    Place the vacuum adapter into the skimmer with the hose and vac head attached and in the pool.
    Get your garden hose on a gentle flow and point it into the skimmer - this will give you a good seal around the vac adapter.
    Put your filter to drain or rinse and turn the pump on.
    This will allow for you to drain your pool to whatever level you desire.
    Honesdale PA
    An easy way to make a soft gasket for the skimmer vacuum adapter is to put a thick bead of silicone seal around the outside edge of the adapter where it mates with the skimer then place it on a piece of wax paper on a flat surface and let the silicone cure for a couple days. Silicone won't stick to wax paper. Bingo...a good flat soft seal.
    i live in kentucky, do you think i need to drain below the returns?
    i had pool company to close before and i doubt they drained below the returns, but i don't know. i never paid any attention to this. do you think i need to where i live? thanks.
    Bucks County PA
    Easy way to tell if the pool company drained below the returns, did you have to fill the pool up when it was opened? If you had to put a good amount of water in chances are they drained the water down.
    Smile Re: quick question-closing now
    ph101, IMO you are fine leaving the water where it is and not worrying about the other 2". You will get a little wetter when plugging the rets and your blower will have to work a little harder to evacuate the lines (you also need to plug them while the air is comming out of them to insure that they remain dry).
    1 other thing to worry about is the cover, if it is a safety cover - no problem, if a watertube cover - draining it too low will keep the cover from being able to float on the surface and it will fall in.
    My computer is acting up right now, so i will end here - if you have any further ?s, post and they will be answered.
    Long Valley, NJ, US.
    I assume you don't have a bottom drain. If you do, just close off skimmer and open bottom drain and drain pool.
    i do have a bottom drain and i did put it on full drain when i was draining...when it got below the skimmer it remained draining okay for a little while, then it trickled out to a little then nothing. i wasn't going to blow the lines out as others on here have said where i live i should be okay and didn't need to. i have drained the filter and the pump. but nothing has been blown out. i did notice a little water still in the skimmer, should i try some way to get that out too and if so, how do i do that too? please advise and thanks
    Question Re: quick question-closing now
    If you're not plugging the lines, why bother lowering the water past the skimmer? (You are going to evacuate the skimmer line, right?)
Closed Thread
  1. Quick question about swimming with 1.5 CC
    By JuJuBee in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-26-2012, 09:14 PM
  2. quick leveling question...
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 05-17-2007, 07:56 AM
  3. Quick CYA question
    By doggie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-15-2007, 02:15 PM
  4. Quick Question ???
    By IMherDad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2007, 03:57 AM
  5. Quick Question About pH DROPPING???
    By PopcornGirl in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-22-2006, 12:18 AM
