Re: quick question-closing now
i do have a bottom drain and i did put it on full drain when i was draining...when it got below the skimmer it remained draining okay for a little while, then it trickled out to a little then nothing. i wasn't going to blow the lines out as others on here have said where i live i should be okay and didn't need to. i have drained the filter and the pump. but nothing has been blown out. i did notice a little water still in the skimmer, should i try some way to get that out too and if so, how do i do that too? please advise and thanks
