Results 1 to 10 of 12
Thread: Thinking of going vinyl rather than gunite
    Jul 2006
    Arkansas
    Default Thinking of going vinyl rather than gunite
    After much deliberation, I'm beginning to think we will go vinyl (do-it-yourself) rather than gunite due to cost. Vinyl owners and builders out there - what is a reasonable estimate for the life of the pool versus the gunite and in your opinion is it worth the money saved?
    Also, if anyone has used any in-ground pools kits, I'd love to hear recommendations. Thanks for any input.
    JBHogfan
    Default Re: Thinking of going vinyl rather than gunite
    There's TONS of posts on this. Each has their advantages and disadvantages.
    But a vinyl liner can last anywhere from 10 days (a crazy story for another time ) to 20 years. Reasonable life expectancy is 5-15 years. The pool structure, though, with maintenance, should last indefinitely.
    I'll check this later--and edit it. Gotta run now.
    Jul 2006
    Arkansas
    Thanks very much for the info. I was most concerned about the structure so that's good to know.
    JBHogfan
    OK,
    Let me see if I can lay out the pros and cons of both. I'm a vinyl pool owner so I AM biased.
    Vinyl Pros
    Expense
    Flexibility--if the ground shifts it can move with it.
    Fast installation
    Easy Replacement
    Low maintenance--Brushing and proper water maintenance.
    Durability--Expect between 5 and 20 years, but 8 to 15 is most likely
    Chemical neutrality--it doesn't affect your water
    Easy to add more returns or lights
    Vinyl Cons
    Appearance
    Fragile--it can be cut by tools, doggy claws, some robotic cleaners
    Can never be drained until replacement time
    Vulnerable to chemicals--excess chlorine fades it, excess acid can soften or melt it. pH MUST be 6.9 or greater.
    VERY brittle in winter
    Repairs are visible.
    Now for tile/plaster/concrete
    Pros
    NOTHING looks as good as a beautifully tiled pool
    With maintenance, can last for decades or longer
    Can tolerate FAR higher chlorine levels and far lower pH levels without damage
    Durable. Claws, tools, robots can't make it leak
    Can be drained dry (with care that ground water isn't high)
    Repairs can be invisible
    Cons
    Expense.
    Time of installation can be much longer than vinyl.
    A bad installation can be expensive to fix.
    A drained pool can float out if ground water is high--far more expensive than replacing a liner.
    Repairs including resurfacing frequently are necessary every 5-10 years
    New pools affect water balance, leeching calcium and raising pH.
    Calcium levels must be maintained between 200 and 400ppm.
    Algae can get into grout in a way it can't in vinyl.
    Anybody else can add pros and cons to both.
    y0manda is offline Registered+ Thread Analyst y0manda 0
    great post carl!
    Jul 2006
    Pearland, TX (Houston suburb)
    JB,
    I am adding my two cents worth. I am fairly new to the forum but have enjoyed reading everyone's comments. I only had one true drawback to the vinyl pools. I enjoy playing/jumping/ running in the pool with the kids. My problem was that I could never keep my footing when in a vinyl pool. It is too slick of a surface for my liking. Having said that, I have no idea what your main use for the pool will be. That may never become a factor. Good luck in your selection and keep us posted.
    keithw is offline Registered+ Thread Analyst keithw 0
    I would add fiberglass into the equation if you are truely planning a DIY install. I put one in myself from start to finish including digging the hole and from a DIY perspective fiberglass is probably easier to install that Vinyl IMO.
    Fiberglass
    Pros
    -Some really neat shapes and colors are available out there.
    -Virtually indestructable. Should last 25+ years.
    -Very limited amount of areas where it could leak.
    -Chemical neutrality--it doesn't affect your water
    -The digging of the hole does not have to be precise since backfill is utilized.
    -Because of above, super duper fast install! Went from dig to backfill to fill in one day.
    -Adding lights, returns, anything is a snap.
    -Can be tiled just like a gunite pool.
    -Very low maintenance.
    Cons
    -More expensive that vinyl but cheaper than gunite.
    -The white shell version can show stains and may need to be cleaned on occassion.
    -Can float out of ground similare to gunite if drained.
    -Shapes are more limited than gunite.
    -Can crack if not properly backfilled.
    -May need a crane it get it in your yard/hole.
    Jul 2006
    Arkansas
    Thanks everyone for the replies - it's certainly a lot to think about. Primarily our pool will be used for the kids (ages 3 through 10). I want my kids to enjoy it while they're young but I also want just a great place to look at in the backyard. Additionally, I do want a really deep end for diving - my husband loves to dive. I considered the fiberglass but wasn't sure if I could find something as large as I want (20X40 with a 10 feet deep end) so I might do some more research into that.
    Although I'm extremely partial to the gunite, I'm afraid that with the gunite I might just be able to get the pool and nothing else whereas with the vinyl I could probably do both a pool and possibly small pool house and more landscaping. Also, didn't add this before but I definately want a spillover spa so that adds to the cost. I've been researching for about 2 years and still am undecided, ha! Thanks for all the assistance everyone - keep those ideas coming!
    JBHogfan
    I have a vinyl IG and have completely drained several time. I do have a vermiculite "hard bottom". No problems what-so-ever. No sure this should be a "con" of vinyl.
    Quote Originally Posted by CJDahl View Post
    It is a con for vinyl if you live in an area with a high water table
  1. From Gunite to Vinyl...
    By aatwatch in forum Pool Equipment & Operations
    Last Post: 06-16-2011, 10:10 PM
  2. Gunite already calcium deposits and small hairline cracks of both plaster and gunite
    By getittogether in forum In-Ground Pool Construction and Repair
    Last Post: 04-10-2011, 01:45 PM
  3. thinking of going with a swg
    By kingcoota in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2010, 12:07 AM
  4. Gunite -vs- Vinyl lined
    By Pool_Mike in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 03:51 PM
