Re: pump will only prime when basket it out
scottsdale,
Are you saying the pump strainer fills up with water except for an air bubble at the top? If so, your pump is primed.It's acceptable for there to be a small air bubble at the top of the pump strainer so long as you're getting good flow through and there's no cavitation.
By the way, do you have your main drain suction line opened completely (if you have one)?
