Results 1 to 10 of 29
Thread: pump will only prime when basket it out
    Ft Lauderdale, Fl
    Default Re: pump will only prime when basket it out
    lol....love the red nail polish while doing pool maintenance though! ; )
    Have you tried a new basket? It's not likely the basket itself causing the problem unless there's some kind of blockage in the basket that you cannot see.
    There wasn't any 'hair" in the pump impeller when you cleaned it, was there?
    If there's a reduction of suction on your filter, there may be some obstruction in your suction lines. The best way to check and clear this is to go to Home Depot or Lowe's and get a plumming "Drain Jet". It attaches to a garden hose, swells the canvas or rubber blatter to plug up the pipe, and forces water into the pipes to clear any obstruction. You would put this into the pipe going back to the pool from the pump basket area (with the lid removed of course).
    Sean Assam
    Scottsdale Arizona
    Yeah, nothing like black goo under red fingernails.
    I tried the Drain king and isolated the drain and the skimmer at different times. Each seemed to have a good flow coming back. The drain is hard to tell because..well, I'm not getting in there to check. But....I put leaves over the drain to see if they floated away from the force of the water and they did...and the drain seems to suck just as it did before.
    That drain king thing shoots a skinny stream of water..pulsating yes, but by the time it makes all those corners how forceful do you think it is?
    If there was a clog, wouldn't I have the same results if the basket was in or out? Not priming?
    The basket is free of any debris, I was concerned that there could be hair that I couldn't see. Some roofing pebbles but I removed them. Same thing.
    There was a little debris in the impeller (try gettin' to that without ruining your manicure!)-removed that and still not priming.
    Kurt..yep. Cleaned and Lubed the O ring. Even the O ring on the drain plug.
    The woman at the poolstore (I know, I know) said that it was probably from the broken basket. She didn't come up with that on her own though AND she didn't have a replacement basket.
    I'm concerned that the pump is failing and isn't strong enough to pull the water through the basket.
    Hopefully I'll find a new basket today.
    Will post the follow up for sure. Thanks for the replies.
    Scottsdale Arizona
    got a replacement basket.
    Not the problem. It still won't prime with the basket in.
    How do you know if the motor is going?
    Honesdale PA
    This whole thread has had me stumped. On the motor, if it isn't making any strange noises, is running at a constant speed, is not overheating, not smoking, and not popping a breaker, then it's OK. That basket looks like it shouldn't restrict the flow much if at all. If I get any brilliant ideas I'll certainly post.
    Jul 2006
    Pearland, TX (Houston suburb)
    Perhaps taking a photo of the pump, in operation, to see how large the bubble is you are speaking of. I don't remember reading this but are you venting your filter, at pump startup, after removing/ replacing the top off of the pump each time? That may help evacuate that bubble. Good luck.
    Scottsdale Arizona
    Poconos- thanks. I appreciate any comments because I'm stumped too.
    My husband is going to put a tachometer? I can't remember what he called it..to measure the output of the motor.
    divnkd101...yep. Bleeding the air off each time. It's an obvious question but thanks for asking because seriously- I feel like I'm totally missing something!
    If you thinking "oh I should ask...nah, she can't be that stupid" Just ASK because I'm blonde.
    The thing is...I've repeatedly removed the basket, old one and new one...and then have been able to to fully prime.
    The bubble..I'll take a picture right now. It's just under the handle thing on the top.
    I'll take a picture.
    Some people consider that primed but it used to be totally free of any air bubbles- which I considered prime. lemme get that photo.
    Scottsdale Arizona
    okay..see where the air is in the pot? I used an arrow but it's hard to see.
    Btw, the air pocket is bigger.
    I was going to take the lid off and prime without the basket so you wouldn't think I was crazy..but I couldn't get the lid off.
