Results 1 to 10 of 14
Thread: I don't understand ...
    Bowling Green, Kentucky
    Default I don't understand ...
    Just opened pool. I have constantly had some kind of material in the bottom of my pool basically for two years now.
    It gathers in clumps, usually long, stringy clumps. Almost looks white, grayish. Some are small, others larger. When you run your hand over it, it dissipates.
    I assumed it was some kind of algae, but I was surprised to see it in such cold water (65 degrees) upon opening.
    Cleaned, shocked, vacuumed to waste following day and looks like I'll have to do the same today. I have followed advice on here to get rid of mustard algae by maintaining shock levels, taking into consideration my CYA level and shocking appropriately.
    Does this stuff sound like mustard algae? Isn't it odd to have that in such cooler temps, early in season? I'm in Kentucky and it's been warm, but I have a solid cover and the water was clear at opening.
    It's been a consistent problem for several years now.
    Help!
    Katy, TX
    Default Re: I don't understand ...
    Well, it's not mustard algae, because that stuff looks like....um..mustardish! It's definitely a yellow-green. Maybe it's white water mold? That generally doesn't happen in Cl pools though.
    I shocked the pool yesterday, scrubbed with brush, and it's back again this morning. Looks just like yesterday, particularly in one spot along crease where pool begins to deepen.
    Was at a dreaded pool store yesterday and described problem to an employee there, who said it sounds like white water mold.
    Gosh dog. Anybody know how to treat that stuff?
    Katy, TX
    Luckily, pools are like horses, when they get sick you shoot them! Wait! No! I mean, when pools get sick, there's one treatment: Lotsa Chlorine. However, let's start first with posting a full workup of your pool water. Then we can go from there.
    Michael
    Ph 7.6
    Cl 10
    TA 120
    CYA 50
    mbar's Avatar
    Ashland, PA
    I had water mold the first year I had my pool - when I was using baquacil. Does it smell like fish?? I kept smelling fish - my husband thought I was crazy! The water was beautiful. Then I started to see those clumps - looked like a wet tissue. It was water mold. It is very hard to clear up with baquacil, but lots of chorine will do the trick! Keep your pool at shock levels for about a week, which with a cya of 50 is at least a chlorine reading of 15. Don't let the chlorine drop below that. When the chlorine starts to hold, keep it for a couple of days more to be sure it is all gone - water mold is tough. Keep your filter running, and backwash.
    Northeast PA
    Katy, TX
    Ya left out Ca, which can also cause white stuff in the pool. Need to do that test too.
    Michael
