Results 1 to 10 of 20
Thread: Leaves on bottom of pool
    Default Re: Leaves on bottom of pool
    Mike, not sure where to get one (Walmart, Home Depot ?). It's ~18" round with 4 wheels, a pole connection and a female hose connection. It works like the polaris, ie venturi action from the hose, pulls leaves etc into the big mesh bag. In fact it's basicly a garden hose driven polaris that you have to direct around the pool with the pole. Perhaps Larry can clarify for me.
    Smile Re: Leaves on bottom of pool
    yes i have it here in my hand, its13 inches wide, 6-7 inches. high, leaf net goes around the top white ring, it goes on your pole , the end of your hose just goes onto the fiting on the base of the bagger, water jets up the bagger netting and the leaves follow its just that simple , bought it at the pool store.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Here's a link to the leaf bagger:
    http://www.wards.com/product-2/64538.htm
    I've yet to see one in any pool store in my area (NC).
    CaryB
    sounds simple. gotta head to my pool store tomorrow to get more salt. so I will ask about this. Thanks all!!
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    My experiece with leaf rakes is that the type and brand make a big difference in how they work. Some are great and the leaves easily move into the bag, others are like a trying to open a lock with a tooth pick. I have an Aquajet pool cleaner, but find it's easier to take 5 minutes to use the leaf rake first before running it. Also have used the leaf bagger or leaf vac that you guys mentioned and find my leaf rake a lot easier to use and faster, not to mention having to deal with the garden hose. I got my rake at HD, it has a soft white mesh bag on it and the rim has a plastic edge on it that is curved to cause the leaves to lift off the bottom.
    so when you hook up the waterhose, where does the other side of the waterhouse go to? The return or just to the water faucet??
    Yes I am a newbie
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Garden hose hooks up to your water faucet, I suppose you could get some adaptors to hook it your return but I think you'd have better pressure from the house water pressure assuming it is at a reasonable level. This of course does add water to the pool every time you use it.
    Man, had allot of wind and blew crap load of leaves into our pool skimmper basket was full and also leaves that sank clogged around my 2 main drains, which allowed no suction to our pool and motor was running like crap. I would not think that it would be so bad.
    I have yet to purchase that leaf catcher, but I am seriously thinking about pulling out my solar cover and drop it in our new pool and hope that would keep majority of the leaves sink below. arrggghh!!
    Yes I am a newbie
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. leaves
    By mrs.rainbow in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-21-2012, 03:32 PM
  3. Can leaves covering bottom valves cause hydrostatic valve to open slightly?
    By frayedend in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-01-2011, 10:10 PM
  4. Leaves and snow/ice
    By denanbob in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-25-2006, 11:35 AM
  5. leaves
    By rainhill in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-20-2006, 06:19 PM
