Sucking Out Lines
Just had my pool closed by the builder (first year with pool) He dropped the level of the water just below the level of the returns and used a shop vac to suck the lines out, he says he prefers this method since he says he can be sure all the water is out of the line. Any thoughts on this. He has been using this method on the hundreds of pool closings he does so I guess it must work.
