Re: Cutting main drain line to relocate equipment
I have heard of plumbers using bread to plug up copper pipes with water in them so that they could solder on a new joint. The bread soaks up any residual water and then will eventually disintigrate and make its way out of the system... I am not sure with 1 1/2 pipe though, that would take one large french stick to plug that one.
