Results 1 to 10 of 46
Thread: AL's Pool Project 10-17-06
    No Need is offline Registered+ Thread Analyst No Need 0
    San Dimas, Ca
    Default Re: AL's Pool Project 10-17-06
    The pool is only half full had to slow down the fill. This morning noticed a chip in the plaster right in the middle of the first step, needless to say I'm not real happy about this.
    I check out the rest of the pool and found a nice 2 inch long gouge on the side right next to the bottom step.
    I called my plaster company this morning, and he is sending out a guy to fix it today! This is the way customer service should be.
    AL
    SeanB. is offline --General User-- Weir Watcher SeanB. 0
    Missouri City, Texas
    Hey, you may want to turn the water back on at a very low flow rate. If you leave it off, you may end up with a permanent water line since it is still curing. As long as the level is rising, even if VERY slow, you should be OK.
    Site owner -- www.troublefreepool.com
    San Dimas, Ca
    Quote Originally Posted by SeanB. View Post
    I do have the water filling slowly, It's about a foot below where they need to repair it. I was hoping to have it filled by noon, now it looks like mid night.
    San Dimas, Ca
    My pool is almost finished! We poured the deck today, now I have to get going on the landscape.
    Northern Kentucky
    Love your pool, especially the wavy lines in the decking... very different and cool!!
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Jul 2006
    Pearland, TX (Houston suburb)
    Al,
    When's the party??? It looks great.
    San Dimas, Ca
    Thanks for the comments Grace, and the party will when the plaster has cured so I can turn on the heater. .
  1. New Member Starting Pool Project
    By Lburg in forum Above-Ground Pool Construction & Repair
    Last Post: 11-06-2012, 10:06 AM
  2. Subcontracting your own pool project?
    By minddeal in forum In-Ground Pool Construction and Repair
    Last Post: 02-28-2007, 10:15 PM
  3. Steve's pool project 1-24-07
    By skamp in forum In-Ground Pool Construction and Repair
    Last Post: 02-20-2007, 02:30 PM
  4. That massive pool restoration project
    By peppercorn in forum In-Ground Pool Construction and Repair
    Last Post: 01-04-2007, 10:10 PM
